RCU Forums - View Single Post - Pump with non-pump carb
Old 10-02-2007 | 10:53 AM
  #50
DarZeelon's Avatar
DarZeelon
Default RE: Pump with non-pump carb
Greg,
Sure there is a 'crossed effect', of the high-speed needle over the part-throttle fuel flow.
This effect is virtually nil at idle and at off-idle settings, but becomes more noticeable at higher throttle settings.
But since the low-speed needle is the smaller orifice at 0-~75% throttle, its effect is much greater than that of high-speed needle, at these settings.
And since the high-speed needle's position cannot be changed in flight, is is a fixed obstruction that must only be adjusted for once.
Changes made subsequently to the high-speed needle's setting, will probably be small enough not to affect the part-throttle range, but this must be checked as a matter of course.
