RCU Forums - View Single Post - Engine cutt-off on EI
Old 10-02-2007 | 02:12 PM
Charlie P.'s Avatar
Charlie P.
Default Engine cutt-off on EI
I am looking seriously at the Fuji 43cc EI and have never owned a model with elec. ignition before. Tower mentions the Great Planes cut-off switch should not be used with this engine (strangely, it is in the "recommended accessories" but if you read the description it says it should not be used).
Is there a difference with EI in a kill switch? Won't grounding the circuit stop the spark as in a non-EI gasser?
What should be the set-up for a kill switch?
Thanks much,
