RE: Need help with setting up
you really are not learning are you?you have had a mountain of problems which are all your own doing.plenty of people have tried to help but you are not taking advice.here is the remedy in plain and simple english.hitec 35 mhz tx with charged battery,hitec 35 mhz rx,charged rx battery,matching crystals,dual or single conversion for the rx depending on model,tx in right mode,ppm or pcm.servos in right slots in rx,battery in right slot and it will work.taking it into a shop and getting them to get it to work when you have been buying parts off ebay would get you shown to the door double quick if i was the proprietor.i know i am sounding harsh but i feel you are needing a good kick up the butt!
