RCU Forums - View Single Post - Need help with setting up
Old 10-02-2007 | 04:04 PM
bigchap
Default RE: Need help with setting up
transmitters are not single or dual conversion,receivers are.if you have a dual conversion crystal in your tx it will say so on the little label.if you do then that is your problem.if not then check your tx is set to the correct shift,i checked on the optic 6 and it is switchable between negative and positive shift,hitec receivers are available in negative and positive shift.just make sure the 2 match.
