RCU Forums - View Single Post - Single / Dual conversion receivers
Old 10-02-2007 | 04:46 PM
nedyob
My Feedback: (67)
Default RE: Single / Dual conversion receivers
I have dual conversion on all my RX's
If you have a PCM RX you will need a TX that has PCM, my Futaba 9C has both PPM (FM) & PCM.
with PCM you can use the fail safe mode in case you loose a signal and the engine will idle down to what you set it to in your TX.
What type of radio equipment do you have currently?
NEDYOB
