ORIGINAL: scratchonly
A FRIEND AT THE FIELD HAD THE SAME PROBLEM, WE FOUND THE PUSHROD INSIDE THE PLASTIC TUBE HAD RUST ON IT, BINDING THE PUSHROD. DISCONNECT THE ROD FROM THE THROTTLE ARM TO ISOLATE THE BINDING TO EITHER THE ROD OR THE ENGINE. YOUR PUSHROD DOES LOOK A LITTLE GRUNGY.
This is a little on line etiquette thing I learned on RCU.....Don't use caps it is like yelling. Thanks for being so helpful with the new guys
