RE: Robart valve issues!
Most common problem with the Robart valves is that you should not allow the servos to push against or over the end points of the valve.
This was a very frequent problem with our early kit builders (SpiderJets F-16) ; problems were solved when we mentioned it clearly in the manuals.
Best Regards,
Nicolas.
