RE: 72" PI cat build
Lay the mushrooms down Bob, it does not have to bee this way! I got the gear box milled down tonight, installed the 12 open shell ceramic nitride bearing's from boca, What i have decided to do on the gear box is install 3 nipples, I have already put a set screw in the stock breather vents hole and sealed with Locktight Blue, One nippled on the bottom and 1 on each corner, I have a high speed oil used in live oiled dentist tools that spin in the 100+K rpm range day in and day out, Then i have a mini pulse style pump that ill use the pump the oil.
