RE: Welcome Weatronic's
Hi,
Yes. The overall length of the antennas has to be the same. If whip antenna length is 12 inches, cut off 12 inches off the original antenna. Make sure you have a good connector.
Make a range check before cut and after cut and analyze the signal strength with the Nav View software.
Gerhard
