RCU Forums - View Single Post - Rx Upside-down - bad idea? Mounting small servos?
Old 10-04-2007 | 11:47 AM
Sergei
Default Rx Upside-down - bad idea? Mounting small servos?
Hi everybody,
did some googling here and on the internet and did no find an answer:
First time I am building a low wing (Modeltech mini magic extra) and easiest position for the receiver would be to stick on velcro upside-down just behind the firewall - easy to connect-disconnect servos etc.
1)I am worried about servos' connection disconnecting from vibration? Anyone here had this problem - is it a bad idea to do that? Any ideas of how to prevent it (servo/battery disconnecting from Rx) if it does happen?
2)How about mounting Rx verically so that servos are connected from the side? Is this a prob?
3)And another beginners question - re:servo mounting:
I have a Hitec 65 micro servo which does not come with usual rubber grommets bigger servo do. Do I simply screw it on straight to my servo tray (fuse side in this case)? Or do I need to do something to cushion it from vibration?
4)I just realised that most of my questions (like questions above) must have been answered in some good RC beginner book already I should read may be? Anyone could recommend a very good one or two?
Thanks very much!
Sergei.
