RCU Forums - View Single Post - Rx Upside-down - bad idea? Mounting small servos?
Old 10-04-2007 | 02:49 PM
-pkh-'s Avatar
-pkh-
Default RE: Rx Upside-down - bad idea? Mounting small servos?
BTW... I used HS-81 servos in mine.
If you wrap the RX in foam, you usually just wedge it into the fuse somewhere, or glue some wood sticks in to hold it in place. I use balsa sticks or popsicle sticks, I just glue them to hold the foam wrapped RX bundle in place. If you use velcro or foam tape, you just stick it to a flat surface inside the fuse. Wrapping in foam isolates it from vibration and protects it in a crash. The foam or velcro tape just helps isolate it from vibration, doesn't help in crash.
