RE: Torch 90 cc new from Brazil
Just maidened my 33% GP Cap 580 with Torch 90cc. Great engine!! Very easy to start!! Tons of compression!!
Fromeco 2600 Li-Ion with MPI reg
Pennzoil 32:1
1.5 turns H/L
Vess 26B - Turned at around 6000 rpm.
Sea Level (Miami, FL)
AUW: 30lbs
Choked, popped after 3rd flip. Started after 2nd flip with choke off. Smooth transition. Got a little hot 230F, so I kept the flights short. It got better after each flight. I took a lunch break and let her rest a little. Engine was literally waking up after each flight and felt killer at the end of the day (1.5 gallons) Feels like it is going to be a powerhouse. I am running stock Johnsons for now but will switch to cans as soon as I get a header made. Also, I removed engine from CAP and will be installing in a 33% SD Models Extra 260. Should weigh around 20-22 pounds = KILLER!!
Will post pics soon.
Keep any eye on this one guys.
Ed
