RCU Forums - View Single Post - Anybody use high torque servos for throttle?
Old 10-04-2007 | 03:37 PM
Da Smak
Banned
Default RE: Anybody use high torque servos for throttle?
ORIGINAL: JRX2ER
ORIGINAL: silverj
I also run a HS-645G for my Ravager's throttle and brake. It used to coast to a stop and now will lock up all four if adjusted to that point! Ihavent gotten around to changing out the steer servo yet but it's a must.
just curious, but does that spring on your throttle servo horn act as a failsafe?
It will do in the event of total electrical power failure, as long as the spring is able to pull the servo horn round, they are more useful than an electrical one if you lose the battery, but you don't find out the batts dead until the car just sits still.
