ORIGINAL: {GBI}Harryball
ORIGINAL: ehroof
lol, sorry but i will disagree with you no matter what you say, no matter how great your business is, after run oil is Made to put in your nitro engine after you run it, automatic trans fluid is NOT and WD40 is NOT, case closed, how can you keep arguing the fact. How am i wrong, what should i admit to? Your not making any sense.
Read the WD40 can youll see. Listen folks, everyone has an opinion on this. WD40 is what i use. That being said use what you want. After run, Tranny fluid, or WD, hell you can use break away if you want. Ehroof and clermont, if you really think after run is any different than tranny fluid an article would be nice. Otherwise its the same stuff. Ehroofs test works the same with after run and tranny fluid.
how did it work with the after run and the wd40 like i said to do? wd wont mix with the moisture
