RE: Orientation tips, please!
And work up to it-- with the smaller helis the rotor wash is not a huge influence above about 4 feet if you're away from walls, trees &c. If you try and push it you can get dangerous-- the heli can be slipping down toward you without changing angular location, and it's very hard to see the change in size.
