RCU Forums - View Single Post - Charging the AXE CP
Old 10-04-2007 | 08:29 PM
badazzbusa
Default RE: Charging the AXE CP
Yeah, if you are going to fly elec. you need a good charger. Get one that can also charge Li-ion and Li-poly batteries also and you will be able to grow into it and won't have to keep buying chargers. The wall chargers that come with any of the kits aren't very good for the packs anyway. A good charger that will charge anything, actually it will charge 2 of anything at once, even if the packs are different types or size and it will work off AC or DC power with the included power suppy is the Hobbico accu cycle elite. It's more expensive than some but it is a great charger and will charge 2 packs where most oters only charge one and most others are DC chargers so you have to power them off your car battery or buy a power supply seperate.
http://www2.towerhobbies.com/cgi-bin...&I=LXEYD4&P=ML
Not sure of your battery ends but you can search for charge plug adapters at Tower and find what you need.
