RE: Tool List
I just checked, Sears has the 16" on sale right now for $99.99. It the one I have and you won't beat it. It will take either the pined blades or you can clamp them in. Once the blade lock get kind of worn in, popping the blade out for going for inside cuts is a snap. It is money well spent. One thing if you get one, turn the speed control way down before you start it up. Mine about danced off the bench (I hadn't bolted it down yet. I was very unhappy with the viberation until I discovered it was set to the highest speed. The slowest speed is about right for balsa and lite ply work.
Don
