RE: Charging the AXE CP
No problem, the charger I showed you will probably do all the batteries you will ever need to charge, NiCD, NiMH, Li-ion and Li-poly. It will do up to a 3 cell Lithium battery (11.1v) and up to 10 cell Ni packs. I'm not sure of a cheaper one that will do everything. The Accu cycle is also very user friendly. You just punch in the battery type and size and press charge, it will select the charge rate or you can manually select it.
