RCU Forums - View Single Post - Rascal 40 conversion
Old 10-04-2007 | 09:45 PM
bobferguson's Avatar
bobferguson
Default RE: Rascal 40 conversion
Could you measure the width, length and depth of the battery area for me. I need about 140mm x 50mm x 26mm to fit 4s2p 4600 A123 packs. But from the pictures I don't think there is enough room. One 4s1p 2300 A123 would be to short a run time. I only use 4s1p A123 in anything bigger than what a 3s1p 2200 fits. So far I have Pulse XT and a Newbee that use them.
ORIGINAL: Red Scholefield
ORIGINAL: highflyer65
Has anyone done a conversion of the Rascal 40 recently.I've read one or two but they were all done back in 02 or 03 . What I'd like to see is motor mount and where you placed equipment .I plan on using an out runner EQ: AXI 2820 or 2826. Any and all help would be greatly appreciated.
Yes, I have converted a Rascal 40. I use the AXI 2826/12 with 3S4200 LiPo or 4s2300 A123. If does quite well. Just mounted the AXI so that the prop would be in the same place as with the Super Tigre 40 that originally powered it. The battery pack went into a hatch underneath and directly behind the original fire wall.
