Well, my plane came today and it is a WillHobby Yak 54. It has in the instructions for a pull pull rudder, CG is 130mm from leading edge at fuse which is right on top of the wing tube, a awsome new color sceem , and the landing gear seems plenty stong enough. So they must have made some changes. On the bad side, just throw the instructions and the hardware packsge in the trash. I did change the colors on the tail/rudder from the blue and white checkers to the picture below. Started building tonight and am going to use a OS Max 1.20AX. as I build I am going to keep as much as I can as far forward to keep up on the CG issues that I have read in this thread.
