RCU Forums - View Single Post - Nexstar Prop
Thread: Nexstar Prop
Old 10-05-2007 | 11:19 AM
hogflyer's Avatar
hogflyer
Default RE: Nexstar Prop
ORIGINAL: hxman
I changed the prop on my nexstar and it seems to always come loose. I have used loctite....
Never ever ever ever use Loctite on a prop nut - it could be very hard to get the nut off. Prop nuts and shafts are hardened steel and it is doubtful you can hurt it. Follow what Ken said, which is what I do. I either use a boxed wrench or crescent wrench (be careful you have it properly adjusted or you could damage the nut).
Hogflyer
