9303 4 servo wing programming
Maybe someone can help, how do I program a 4 servo wing into the X9303? I have the Hangar 9 35% 260, and it uses 2 servos per aileron, I've been using matchboxes, but have now changed to the 9ch receiver and want to do it in the radio. What I've come up against is there doesn't seem to be any way to use the Flaperon mixing, so I have to choose normal wing type, then slave gear to aileron, and Aux 3 to flap, and then make a mix in the regular transmitter programming to link it all together. Is that correct? Doing it that way works, but isn't nearly as nice as having the flaperon mix turned on, and just slaving the channels in the device select screen, but it won't let me do that!
