RCU Forums - View Single Post - YS50st has lost compression, send it in?
Old 10-05-2007 | 01:51 PM
Troy Newman
Default RE: YS50st has lost compression, send it in?
Yes I assumed the head bolts were tight but this would do the same.
A damaged ring is possible but not very likely I have seen it once on a engine from running. usually if a damaged ring is there its from the installing it and breaking the ring.
I did this once. Broke the ring putting it in.
Troy Newman
Team YS
