RCU Forums - View Single Post - Wren SS spool up time gnd vs air differences
Old 10-06-2007 | 06:03 PM
siclick33
Default RE: Wren SS spool up time gnd vs air differences
You don't necessarily need to return the ECU to get the data checked. If you have the PC lead (available from Wren) you can download it yourself and look at what is going on. It will easily tell you obvious things such as if the pump is being limited by overtemp etc. If you need more analysis then you can email them the data.
This saves you ripping apart the model and may give you a quicker answer.
