RCU Forums - View Single Post - Landing set up
Old 10-06-2007 | 11:08 PM
noahb
My Feedback: (67)
Default RE: Landing set up
ok, here is what I have:
in dev. select: Flap is aux 2 switch. Trim off. Also, this is where you will turn your FM on. You don't have to, just my pref. Aux 2 (I have it set to Flap Lev) as I use this for my brakes.
Then go to list:
Flap system: Auto Land inh. Flap normal mine is at 87%, mid is D34%, land is D100%. over on the far right menu you will see FM if you have them setup. FM0: sw, FM1: normal, FM2: normal. This will shut the flaps off in the FM1 and 2.
I think that is it.
Again, I like the flight modes as I have it setup so that i don't have to sit there and keep flipping lots of diffrent switches for dual rates and stuff.
Also, I would not rec. auto land. The reason is on a windy day, you will have to come in under substantial power and it could get you into a stall or something. I like to be able to flip my flaps on and off without anything effecting them.
If you are still confused, shoot me your email address via PM or email and I can take some screen shots or even call you.
Larry
