Best way to apply trim lines with curves??
Hi all, I was wondering if anyone can suggest the best way to apply a stripe of trim, if the stripe needs to make a curve (as in the attached picture).
In the past, I have attempted to cut the trim piece out with the curve in it, but the results were marginal at best.
I'm covering my 1/3 GP 330L and want this to look good. I'm using ULTRACOTE which from my expierence is much easier to bend & manage the monekote, but dont know if I'll be able to use one straight piece of trim & curve it as I iron it down. This method did not work on my previous attempts on my old Sig SE using monekote.
