Best way to apply trim lines with curves??
One method...which would require a little more work and covering, would be to make a template of the piece you want cut (I use a roll of butcher's paper I got a SAM's club). Then use that template to cut out the monocote, then just lay it down and iron it. Again, it's a lot of work, but if you want it perfect, give it a try.
