Well, here's how it went using the "Slow as you go & lots of heat" method...actually turned out pretty well, if your a couple of feet away, you cant see the "Slight" wrinkling of the trim line as it makes the bend. I used a single 1/4" strip of covering & a lot of heat to make the bend.
This is my first Giant scale & HOLY COW does it take a long time to do the covering right!...
http://www.chadfrisby.com/milehighae...op/index1.html
Thanks for the input guys
