RCU Forums - View Single Post - Elan, which servos would you go with 8411 or Hitec 5645
Old 10-07-2007 | 05:29 AM
rcguy!'s Avatar
rcguy!
My Feedback: (69)
Default RE: Elan, which servos would you go with 8411 or Hitec 5645
I use a bit different setup. No regulators at all. I use 2pcs 5 cell NimH packs. For the Elan I would go with 2000Mah each. Dual switch harnesses and plug the "extra" battery in an unused servo port or thru a "Y" harness on the retract or brake channel. I've seen to many failures due to inadequate regulator rating. No need to isolate the packs either! I recommend the NO BS elite cells at 7mh. Keep it simple.
The Hitec 5645 would do fine...BUT the JR8411's will give stomping performance!
Dave
