RE: tornado bb problem
Thats probably burnt fuel from the exhaust making your fuel dark, Kinda sounds like you could lean it out just a tiny bit more. Also if you coil a little extra fuel line above the fuel tank it stops a whole lot of burnt fuel from making the cycle into the tank. If the seal were bad it would be running way to lean[:@]and the exhaust would be dry[&o]
