ORIGINAL: Ruizmilton
I forgot to ask, is your battery really a ni-cad? are you sure it's not a ni-mh? I would understand them recommending not to use ni-mh batteries because of high internal resistance, anolther giveaway is the capacity, I could be wrong but I believe 3300's come only as ni-mh's
Hi again Ruiz-the batt is nimh not nicad that wren says to use. I think, based on youre above statement that we are on the same page. Im thinking I need a 7.4 volt Lipo 1500mah to do the trick. Im thinkinking the reason wren says NOT to use nimh batts. is a lower amperage than nicad or lipo-
