RCU Forums - View Single Post - Cermark Pitts Build/Assembly
Old 10-07-2007 | 09:58 PM
  #43
bladerunner1955
My Feedback: (72)
Default RE: Cermark Pitts Build/Assembly
ORIGINAL: V2PLUS10
Now you've got my brain spinning......I've looked up the motor and speed controller from Hobby-lobby, but batteries are a bit of a mystery to me....did you use one 10 cell pack, or two 5 cell packs in series? What size (ma) are they? Are you using A123 batteries? How about flight duration and chargers? All up weight?
Thanks!!!
Randy
Hi Randy, I use 2, 5 cell packs in series, I use Thunder Power Extreme and they are 5000 mah. I can get 2, 5 min flights no problem. But everyone fly different so I would fly a 5 min flight and see what mah you put back into the packs. You wont want much more than 4000 mah going back in to stay on the safe side. I fly like I stole the plane and the motor only gets a little warm. I swing a 20/12 prop. Not sure about the weight. I have a new in box Great Planes 1/3 scale pitts I need to assemble soon. Now the 1/3 scale pitts is going to get the 5345/middle one with 12 cells,,,look out when that goes up!
