Mike HELP!! Ignition module????
Mike,
This motor has less then 2 gallons of fuel through it.
I will send it back tomorrow by UPS, you should have it by Friday.
Any Idea on cost and more important, turn around time?
I assume all you need sent back is the motor with the gray wire attached to the back of the motor.
Or will you need the ignition module also?
Thanks Steve
