RCU Forums - View Single Post - Purchasing advice
Old 10-08-2007 | 06:17 PM
wackywheelz's Avatar
wackywheelz
Default RE: Purchasing advice
Recently reports on many forums (including here) are that the PzIII and likely others are now having there trackpins glued at the factory rather than relying on the interference fit -- good for endurance, harder when you wanna take the buggers off (but its not impossible).
Go with the PzIII S&S, you wouldnt wanna shell out for a Tamiya then find you don't wanna be in it - plus with them (Tamiya) theres building, paints, glue etc, factory errors/fit problems/part troubles and even if you've shell out a few hundred for the kit, and build it, you still aren't RTR and need all the crystals and receiver gear, controller blah blah). Heng Long - cheap, tons of upgrades available and RTR out of the box (unless you're really unlucky)
