10 / 6 prop for LA 40 might work better. A good starting point for the air bleed opening is open more than 3/4 open. put a "T" pin in the hole and GENTLY close it on the pin. Remove pin and run it. It should be close enough to start your pinch testing. This works pretty well and so does visually starting at 50% closed ( or open depending on your mood
