RE: Will this engine set-up cause problems?
Could just flip the carb around, would be tight on the muffler but at least the needle valve wouldn't be pointed straight down. Too bad you couldn't just flip the cylinder around 180 degrees too.
I have to side with the rebuild the whole front end right now crew. You'll be kicking yourself a year down the road when that plane is a big PITA to work with at the field....
Andy
