RCU Forums - View Single Post - switch 3 blade prop to 2 blade?
Old 10-08-2007 | 08:28 PM
ELTIGRE
Default RE: switch 3 blade prop to 2 blade?
well Boys I have news for you. changing props will NOT "give you more power" . the Hp of your engine will not change one iotta. it will change how the power you have is transmited to the load & thereby the air affecting thrust out put.. a two blade will out perform the 3 blade.
