RE: Redcats Monsoon Thread
here are some pics of the mod i did on my vtx, its very simple, i used a 1/4'' drill bit then a file. you can use a cutting bit, hacksaw, jigsaw, your teeth (if they are strong enough), just about anything. just extend the flywheel hole about another 1/2 inch to the front of the vehicle. then use a bump start engine or cut the backplate to slide in between the engine mount, gonna need a starter box after that, the holes for the pull starter will be gone. maybe the top two holes alone will work if you want to try it.
