ORIGINAL: Bad_Daddy
If the full scale has 4 degrees, you already have your answer.
Sorry, but no.....not so simple. Apologies for calling you out on this, Big Daddy.[&o]
It's completely dependent upon the C/L and and anticipated cruise speed at a given weight. The target incidence is the one that produces X lift to fly X weight at Y speed over a Z wing. Exactly NONE of those variable are the same as the full-size and the ratios between them will be different as well. Not even an exact scale wing will produce an apples-apples comparison due to the effect of reynolds numbers.
IMHO.........
