RCU Forums - View Single Post - Will this engine set-up cause problems?
Old 10-09-2007 | 05:20 AM
jetmech05
Default RE: Will this engine set-up cause problems?
Look at your plans in the picture..the pic showing the firewall from the back, the second pic you posted..see the slot for the motor mount isn't centered when compaired the the nose wheel bearing mount? thats your thrust angle....the pic showing the engine from the front clearly shows the the thrust angle is backwards
