RCU Forums - View Single Post - Jet-1A gear on small AD Scorpion
Old 10-09-2007 | 10:16 AM
john agnew
Default RE: Jet-1A gear on small AD Scorpion
Stephane
I do not know the answer to that Stephane. I don't think there is much difference. I would suggest you make a card template using the Jet 1A leg and wheel and then make the cut outs in the Scorpion fuselage . All I did was to make the cut out for the retract, fit the retract and leg / wheel, raise the gear and then draw round the wheel with a marker pen. I then cut out the opening and finished it with a Dremel sanding drum.
Best regards
John
