RCU Forums - View Single Post - Servo reverse on a switch, 9C radio
Old 10-09-2007 | 01:29 PM
Bax
Default RE: Servo reverse on a switch, 9C radio
This would work on a 9Z or higher transmitter, where you could set that up in a condition. However, it can't be done with a 9C. If you mixed elevator with itself and reversed the mix percentage, you'd wind up with zero control movement when you move the stick. We don't know of a way to make the elevator reverse with a switch flip.
