ORIGINAL: sdp30
Yes the light changes color when i throttle but very low power to the motor. I tried another ESC with the same motor and connectors and it worked fine.
You pretty much answered your own question right there.
If you're sure the esc is set up right and everything works fine with a different esc then you've gotten a bad esc. It happens. Call or take it back to where you got it.
