RCU Forums - View Single Post - Alpha 60 RTF
Thread: Alpha 60 RTF
Old 10-09-2007 | 07:17 PM
imora99
Default RE: Alpha 60 RTF
Hi Scott,
I emptied the fuel tank as you indicated and obviously there was a improvement. Still the plane tilts down by the nose but not as bad as it was before. For sure the fuel was adding a lot of weight.
Now I have another problem. Every time I try to start the engine the bolt that holds the propeler becomes loose. The first time it happened I thought maybe I didn“t tightened it hard enough, so I did it again making sure this time it was pretty tight. Once again, as soon as I applied the starter to the cone on the propeler it got loose again, so much so that the propeller just comes off. I thought about putting a preshure washer but there is barelly any thread left for the bolt, so the washer won't fit.
Has anyone experienced something like this with your Alphas? I have added a few pics so you can see how I am fitting the propeller, that to me looks exactly as the manual indicates.
Thanks for your suggestions.
ID:	779859   Click image for larger version
ID:	779860   Click image for larger version
