Servo Synch
It's this possible?
I want to use the servo sync feature to make sure two separated elevator halves are aligned. to achieve that, I will temporarily connect the two separated halves together (wood + clamp). Then I will tell Weatronic to sync one servo with the other. Once that's finished, I will take the clamp off. At that point, I will expect the halves to be perfectly aligned at all defined positions.
Edgar
PD: Assuming it's possible, is there any way to retain that information if I change the output to a different channel? The application will be to change from elevator only to taileron function
