RCU Forums - View Single Post - quick ?????
Thread: quick ?????
Old 10-09-2007 | 08:34 PM
ryan_t888's Avatar
ryan_t888
Default RE: quick ?????
The Jeti 600 will work. Its good for 60A!
I'm concerned about the GTX OB. It is very limited. I looked in to this a while ago and found threads saying people had an extremely hard time finding parts. Many people did not like the 4mm prop limitation for a high powered outboard. You will make somewhere over 700 watts on 20 cells.
If you went with a 3.5cc lower, you could still use an 800 motor. It will be far more reliable and more efficient. You can also run metal props.
Ryan
