RCU Forums - View Single Post - Alpha 60 RTF
Thread: Alpha 60 RTF
Old 10-09-2007 | 10:29 PM
jagnweiner
Default RE: Alpha 60 RTF
It hasn't happened with my Alphas, but has with other planes. One thing that sometimes works is to make a washer out of sandpaper the diameter of the prop hub. Put it between the back of the spinner and the thrust washer of the engine. Not sure what you are using to tighten the nut with, but you should use a good size crescent wrench or box-end wrench. The 4 way glow plug wrench won't apply enough leverage.
Good luck!
