ORIGINAL: thestratcat
how do you figure a set of Align 315mm blades would work on the CP? that's the only set I can find..
That's over a 60mm change in length from stock Axe to Align blades. You could change pitch with separate Tx... a smaller pinion on the motor would just drop the head speed... a bigger pinion would pull more amps than designed for... install a bigger motor and esc... might need a longer boom... Me thinks you're out of the park on this. Please tell me you posted in the wrong forum.
