RE: Jet-1A gear on small AD Scorpion
Stephane
I have just downloaded the template for the wheel cut out from the AD website and checked it against my own model. Assuming the new models have the same cut out you would have to increase the wheel cut out to the front as the rear offset on the Behotec legs looks to be about 8-10mm more than the Jet 1A legs. Also , because of the position of the former in front of the gear position the biggest wheel you can use with the Jet 1A legs is about 70mm, this is not a problem as my Scorpion has 66mm Intairco main wheels and flies ok from grass. Hope this helps.
Best regards
John
