ORIGINAL: acarter
ORIGINAL: Hossfly
would be to saw the glued joint apart. Using the belt sander,
don't you mean band saw
and if so, unless you have a super huge band saw, the wing won't fit, meaning it will hit the throat of the saw, i think if your going to saw it the best tool to use would be a scroll saw, the blade is smaller and it doesn't matter how long the wing is
I'm pretty sure he meant belt sander. You can get them on a stand similar to a bench grinder, or you can get the handheld power belt sanders.
